Replacing wings - lower sill bolt issue
Hello,
I successfully replaced my front wings with no major issues, however when putting my new ones on the bolt to affix the wing to the sill was just spinning into thin air. My question is how does this affix/screw in? Is there some sort of plate/something it should fix into but is missing?
The wing is currently secured everywhere but here, on both sides!
Thanks.
Bump?
there should be a square hole with a metal clip u press in the bolt screws into that.
i dont have a picture of one right now.
Regards Volkswarren
X2 1983 A REG EW CAMPAIGN In WHITE(Awaiting full rebuild solid body) :thumbs: & T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only)  or an A reg Lhasa Green or White Gti to restore, also consider  Black, Red or Blue, Also Golf Driver Project Wanted anything considered WHY
If you can't the fixing don't worry about it, there is enough bolts holding it on inside the wheel arch.
I did not bother with the bottom fixing on my Mk1 Scirocco as the hole in the pattern wings did not line up with the hole in the car so just left it off.
Thank you!
If you do have a pic that would be good! :o)
Thank you!
best i can do
http://www.rosepassion.com/fr/cat/porsche-944-1991-944-s2-cabrio-boite-manuelle-5-vitesses/M454/carrosserie/aile-avant/B297/aile-avant-cache-passage-de-roue/I4732/plaquette-elastique/P359
n0120622 i think is the part number, dont know if they are still a stock item.
Regards Volkswarren
volkswarren said
Thank you!
best i can do
Wow, thank you. I  best get hunting!
