Rear arch lip delete instead of rolling
(In Topic #170314)
Currently restoring my mk1 (been going on for a while now..).
Anyways i'm doing the rear arches now, but there is one thing i've been wondering about.. seeing as i havent found anyone asking the same question.
When my car is done i plan to get it down to earth and have the wheels fill the arches really well, but i thought instead of rolling the arches as you would normally do why not just delete the inner lip and seam weld the inner and outer lips together and have a pretty much non-existent flange aswell as keeping the panels strength?
I plan on leaving 1-2mm of the flange on the outer arch and just weld it together with the inner where the ends meet, but my uncertainty brought me here to ask if its really stupid to do this??
I may not delete the lip all the way around, but atleast a good portion of the top, if anyone has any feedback on my idea it would have been great!
Here s a really rough sketch
I hate rust.
There could be a reason no one has done it before?
If you do catch with the cut lip you'll do more tyre damage for sure.
Best option is to roll the lip. If you need to remove the return lip to gain extra clearance then rather than weld I'd bond the inner/outer lip together with a PU adhesive. No heat related distortion that way.
I hate rust.
It's done by using the cars wheel to rotate the bat between the arch and roll it back. It needs to be done either with coilovers to allow the correct arch/wheel gap to get the bat in or else with a bat/pole/pipe of suitable dia to fit the existing gap.
You can rent an arch roller for a weekend rather than buy one.
