Radiator bracket bolts
(In Topic #232897)
Hi,
Does anyone know what size bolts I need to fit the radiator brackets?
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
Regional Host NE
Re: Radiator bracket bolts
M6mk1newbie said
Hi,
Sent from my SM-G955F using Tapatalk
Thank you
Hey there! I know this answer comes a bit late, but for others who might have the same question, I've got you covered. You'll need to check your specific make and model to be sure, but typically, radiator bracket bolts are either M8 or M10 size. Make sure to also check the thread pitch, as that can vary. And hey, if you need some bolts or screws, I found a great site called Scrooz that has a ton of options. Here's the link: https://www.scrooz.com.au/. By the way, I'm new here on the forum, so thanks for having me!
m6 X 22 or longer IIRC the same as most attachment bolts VWish.
I used a tad longer ones, but on all my cabby's they had a plastic clip on the left side as you look at it, that I changed over to a bolt and nut.
Hope it helps.
Hope it helps.
Regional Host NE
Hope it helps.
m6 for sure
