Plastic trim \ beading
Hi folks the plastic trim that is between the side of the windscreen and the door had come off on my 89 GTi cabby.  Any ideas where i can get replacement or fitting.  It basically goes over a spur.  Ive had a good look around but cant find one or two…
See Pic:
Plast bit
Last edit: by easygeeza
Keep an eye on the breaking section and end PMs to golf-bitz, funk-satr, hibbs etc.
I think its pretty hard to find a pair in good condition
South West Regional Host
Previous;
Current;
It's known as the A pillar trim.
They tend to be expensive too.
Do you need both or just one. If one which one? Passenger side or drivers side?
They used to be £14 from vw when you could buy them, I brought both sides about 10 years ago and how one has a broken bit at the top, annoying that they are so expensive to buy now….
Hi, could anyone help as I need a pair of these please
155853705A left
155853706A right
VW heritage shows them at 29 pounds each but out of stock
https://www.vwheritage.com/shop/155853705A/moulding-for-a-pillar-left-mk1-golf-cabriolet/
Briano1234 said
155853705A left
155853706A right
Do vw still supply these?
No these are pattern parts.
You could try werks34.de
Or volkswagenclassicparts.de
Use those numbers in the search box there.
Think Volkswagen classic parts have some of the old VW tooling.
Ideally looking for second hand ones as not looking to spend much. Is anyone breaking a mk1 Cabby?
Second hand are usually cracked or hard to find a good matching pair.
