option codes a47 w57 715 731
(In Topic #201578)
Any one got any ideas what they are. not listed in the post on codes, which seems to be for non UK codes. Would be good to make a more relevant list for UK spec cars
Last edit: by sporttrucker
Check out this Swiss site - http://www.type17.ch/cms/index.php?option=com_content&view=article&id=15:les-codes-option&catid=25:les-codes
The only code I could find to match the one's you're after was 715…. If correct it denotes, "Rear fog light wiring".
Below is a cut'n'paste of the entire list courtesy of 'Google translate', though check out the whole site, lots of interesting stuff.
Codes | |||
Sunday, 12 December 2010 11:15 | |||
Code: | Corresponding option: | Note: | Specialty: |
61 | Bronze doors windows 4 | ||
A 68 | Common GTI F / D and chassis I / Rabbits and More | ||
A 80 | White 4 door windows | ||
R 39 | Radio Braunsweig II (Blaupunkt) | ||
W 64 | Golf Pirelli without extension and painted bumpers | "D .." | |
W 65 | Golf Pirelli with flares and painted bumpers | LA3A / L90E / | "D .." |
10 | And mesh side panel | 2 DG doors | "D" German Post |
18 | Padded steering wheel | ||
20 | Speedometer in miles | ||
22 | Sealed beam headlights, | ||
26 | Active coal Reservoir for reabsorption oil fumes | ||
32 | Fuel cap with lock | ||
34 | Strengthened rear springs | "I" | |
38 | No passenger seat | 2 DG doors | |
39 | Plate instead of the rear seat | 2 DG doors | "D" German Post |
44 | Seatbelt AV 2 points (retaining automation) and knee protectors | ||
46 | Side indicators | "DK .." ".. N", "IL ..", "I .." | |
48 | Door trim, armrest, ashtray and rear seat rest | Police | |
49 | Wear indicator of the brake pad | DG | |
50 | Lamp for dual circuit brake and handbrake | ||
62 | Sun visor without mirror and modified silencer | "S" | |
78 | Leatherette instead of tissues | ||
82 | Backup box fixing | ||
83 | Attaching the warning triangle | ||
86 | Drum Brake catching car RN | "S" | |
89 | Laminated glass windshield | ||
100 | Multifunction display (MFA) | Golf GTI, Jetta GLI CLI, Scirocco GLI GLI, GTI, GTS | "F ..", "B ..", "NL .." |
103 | Reinforced shock absorbers | ||
104 | Adjustable lighting of the dials | ||
105 | Keihin | EM | "S" "CH" |
106 | Trim, special design fabrics | "D" German Post | |
123 | Special part-worming | "S ..", "L ..", "IL .." | |
124 | Light yellow headlight bulbs | "F .." | |
130 | Abdominal Belt AR (Automatic) | 539 2048001 >> | |
138 | Floor mats and additional coating | Rubber | "D" German Post |
155 | Chrome trim | ||
156 | Air filter for dusty areas | Diesel | |
157 | Carburetor engine, 4 cylinders | 1.6l, 55 kilowatts | "S", "OFF" FN |
>> 179 3750000 | |||
>> 539 2037777 |
160 | Powerful warning on | Golf, Jetta | |
162 | Rib rubber bumper | Golf | |
168 | Gear calibrated for balancing tachograph and totalizer | ||
179 | Trim, special design fabrics | "D" German Post | |
183 | Lap belt AR (Automatic) | ||
184 | 3-point seat belts for front seats | ||
186 | 3-point seat belts for rear seats | ||
187 | Headlamps for left-hand traffic | ||
188 | Vehicle use in warm countries | ||
193 | Application prescription exhaust and electrical equipment | "J" | |
197 | common to convertibles / tailgate cab? | ||
206 | Retro dimming interior | ||
208 | Coupling | ||
222 | Diesel 4-cylinder | 1.6l, 40 kilowatts | |
>> 1-C-999999 | Diesel: CR | ||
1.D-000001 >> | Diesel: JK | ||
224 | Safety covers | ||
227 | Headrests front seats | ||
228 | Table padded edge | Golf, Jetta | |
229 | Headrests for rear seat | Jetta | |
238 | Connecting headlights day | "S" | |
240 | Engine equipped with concave head piston for low-octane fuel | >> 15-C-010101 | GH |
>> 1-C-381167 | |||
>> 53-C-026 473 | |||
245 | AR glass non-dégivrable | ||
249 | 3-speed automatic transmission | ||
255 | Indicator shift and consumption | Formel E | |
258 | Adjustable head restraints for front seats | ||
261 | Outside mirror (plane) | passenger side | |
264 | Commercial tôlée | ||
265 | AR No chairs or folders with bottom plate for chest and side cladding hard fiber | "DK" | |
268 | Empty-pocket under seat | ||
276 | Reinforced body | ||
277 | 4-cylinder engine, carburettor | 1.1l 38kw | "CH" |
FJ012122 >> | |||
283 | Braking compensator | ||
288 | Headlight | ||
303 | Motor protection framework | 1.5l - 1.8l | |
308 | Air spring instead hatchback spport | ||
309 | 4.5x13 rim plate, passenger handle and shockproof profile PC AR | DG | "D" German Post |
335 | Exhaust pipe | central | "A" Scirocco |
340 | Seat and backrest has electric heating | before | |
341 | Central locking | Scirocco | |
344 | Industrial carbureted engine, 4 cylinders | 1.1L / 37 kilowatts | |
Diesel industrial engine, 4 cylinders | 1.6l / 40 kilowatts | ||
355 | Turbo-diesel engine, 4 cylinders | 1.6l / 51 kilowatts | Diesel T-CY |
358 | Modified mounting valves for gas recycling | DD >> >> 179 3750000 539 220000 | "S", "OFF" |
376 | Carburetor engine, 4 cylinders with gas purification system | 1,3l / 43 kilowatts Type GS | "S ..", "CH .." |
To K-Jetronic injection engine, four cylinders, with gas purification system | 1,8l / 82 kilowatts kind JJ | "S ..", "CH .." | |
398 | Retro ext. (map) dégivrable and electrically adjustable driver's side | Scirocco | |
408 | Sheet metal rims 5.5 J * 13 | Golf GTI, Jetta GLI CLI, Scirocco GLI GLI, GTI, GTS | |
409 | Sport seat | before | Code KY / ZX |
415 | Aluminum disc wheels | 5 J * 13 ET45 | |
416 | Safety steering wheel | ||
423 | |||
425 | Windscreen wiper / washer Rear | Golf, Scirocco |
430 | Windshield green heat-insulating tinted green | ||
451 | Alloy wheels | 5.5 * J 13 ET38 | |
471 | Version Sport | ||
477 | Alloy wheels | 5.5 * J 13 ET38 | Jetta |
480 | Clutch 210 mm | ||
481 | 5-speed manual gearbox 4 + E | 1.5 l - 1.7 l | |
482 | Alloy wheels 5.5x13 ET 38 | >> 15-B-014 000 | |
>> 16-B-325000 | |||
>> 17-B-325000 | |||
>> 53-B-050000 | |||
482 | Alloy wheels 5x13 ET 45 | >> 15-B-014 000 | |
>> 16-B-325000 | |||
>> 17-B-325000 | |||
>> 53-B-050000 | |||
485 | Aluminum rim | Version Sport | |
506 | Booster | ||
522 | Partition net | 2 DG doors | German positions |
527 | Outside mirror (convex) adjustable from Inter. | passenger side | |
528 | Outside mirror (convex) | passenger side | |
541 | 5-speed manual gearbox | 1,6l - 1,8l | K-Jetronic |
551 | Iodine headlights | H4 | |
555 | Transmission 4-speed | 1.5 l - 1.7 l | |
556 | K-Jetronic injection | ||
559 | Prepared for subsequent installation of an air conditioning | ||
560 | Manually operated sliding roof steel | ||
561 | Deflector | ||
565 | Sports steering wheel | ||
568 | Green heat-insulating side windows tinted green | ||
571 | Fire back antibroulliard | ||
572 | Two tone horn / horn multiple sound | ||
573 | Air conditioning | ||
574 | Rim sheet 13 5 J * | Golf | |
589 | Injection 4-cylinder engine | K-Jetronic 1.6L 81kW >>> "C .." 999999 EG, | |
K-Jetronic 1.8L 82Kw "D .." 000001 >> DX-DD | |||
591 | Empty-pocket table in passenger aboard | Golf, Jetta | |
598 | Engine 4 cylinders carburetor 1.3 L - 44 Kw | GF | |
599 | Engine 4 cylinders carburetor 1.6 L - 63 Kw | EN | Jetta, Scirocco |
600 | Engine 4 cylinders carburetor 1.5 L - 51 Kw | JB | |
602 | Luxury Facilities | Golf GL, GLI, Jetta GL GTI, Scirocco GL GLI, GLI | |
603 | Luxury Facilities | Golf CL Jetta CL, CLI | |
608 | Version Australia | "AUS" | |
613 | 12v and comprehensive deworming Equipment | ||
616 | Reversing light fires in AR | ||
618 | Alternator 55 A | ||
619 | Alternator 65 A | ||
633 | Electrical Interference suppressed completely | ||
642 | Preheat intake air | T-Diesel | |
643 | Storage lockers for front doors. | Golf, Jetta | |
652 | Washing-scanning relay tbd. Intermitant | ||
656 | Front seat with height adjustment | Scirocco | |
657 | Hydraulic power steering | ||
659 | Fog iodine (front, white or yellow "F") | ||
673 | Speedometer flexible sealed | ||
675 | Tachometer | ||
700 | Special series "Scirocco" | 537 2058001 537 2075402 >> >> | |
701 | Special series "Scirocco SL" | 53-B-004 069 >> | "D" |
702 | Special series "Scirocco CL" | 53-B-004 069 >> | "D" |
704 | Hydraulic power steering | Golf | "D .." |
704 | Special series "Scirocco SL" | 53-B-004 069 >> | "B" |
705 | Special series "Scirocco GTS" | 53 D 002 820 >> | Scirocco |
705 | Special series "Scirocco SL" | 53-B-004 069 >> | "F" |
705 | Spécaile series "Scirocco GL" | 539 2075001 >> | |
705 | AAC cast | FA FJ012122 >> 470358 >> | |
706 | Special series "Scirocco CL" | 53-B-004 069 >> | "I" |
707 | Special series Golf GTI (leather steering wheel) | 17 D 498 000 >> | Golf GTI |
708 | Special series "82 Rabbit" | Golf | "TO.." |
710 | Yellow headlights | ||
712 | Special series "Golf GTI 4-door" | C 17 17 250 557 >> >> 999999 C | Golf GTI |
Special series "Golf GTI 4-door" | C 17 17 470 001 >> >> 999999 C | Golf GTI "D .." | |
Special series "Golf GTI" with bumpers, wing mirrors and extension in the vehicle color | 17 D 448 319 >> according observations D 17 498 000 >> | Golf GTI |
715 | Rear fog lights wiring | all E and F CH | all finishes |
715 | Special series "SL Jetta" | "D", "NL" | |
720 | Injection Pump | "CAV" | Diesel |
722 | Special series "Golf SC" | 17-B-100001 >> | "D", "DK" END "," B "," NL "," F " |
724 | Special anniversary series "3 million Golf" | 179 3361001 179 3750000 >> >> | |
725 | Special series "Golf GTD" | C 17 550 001 >> | Turbo-Diesel |
726 | Special series "Golf LX" | 17 D 450 001 >> | Golf |
Special series "Jetta LX" | 16 E 010 001 >> | Jetta | |
727 | Special series "Golf GX" | 17 D 450 001 >> | Golf |
730 | Special series "Jetta TX" | 16 E 010 001 >> | Jetta |
733 | Bv Oettinger motor vehicle with | FP | |
734 | Special series "Scirocco GTX" | D 53 021 698 >> | Scirocco |
Special series "Jetta CL" exterior paint with black metal panel and padded edge | 16 D 448 319 >> | Jetta | |
Special series "Golf cabriolet" with white exterior and interior trim, alloy wheels, sports seats and steering wheels and athermal windows | 15 D 012 001 >> | Golf cabriolet | |
738 | black faux fur carpet flush | all E and F CH | Corrosion? |
739 | Exhaust system | "TO" | |
741 | Carburetor 036 129 129 015m incandes.036 017a | GF | |
Carburetor incandes.036 015r 036 129 129 017B | GG: Formel E | ||
742 | Special series "Golf M" | 179 3120001 179 3750000 >> >> | "NL" |
745 | Special series "Golf MX" | 179 3120001 179 3750000 >> >> | "NL" |
747 | Special series "Golf" | 179 3120001 179 3750000 >> >> | "A", "B", "DK" |
750 | Pirelli rim 6 * 14 | "D" | |
751 | Alu rim 5.5x13 | 17-D-448 319 >> >> 11-D-750000 | "B", "GB", "I", "NL" Golf GTI |
751 | Special series "Golf" | 179 3120001 179 3750000 >> >> | "F", "N" |
752 | Alu rim AVUS 6 * 14 (Quartett) | ||
755 | Special series Rabbit GTI | 17-D-750001 >> 17-E-010001 >> | "D" Importing Countries |
756 | Golf Special Series LX with radio "Braunschweig" and serial version of dashboard | 17-D-600001 >> | "D" Golf LX |
771 | Locking seat belts | All VW CH | |
775 | |||
921 | Totalizer | "S" Diesel | |
929 | Cover for front and rear wings cuts | Basic version | |
931 | Outside mirror (plane) adjustable from the inside | passenger side | |
935 | Transistorized ignition | Scirocco | |
937 | Rigid sky | ||
981 | Leather seats | ||
997 | Mirror ext. (map), defrost and passenger side power adjustable | Scirocco | |
998 | Mirror ext. (convex), defrost and passenger side power adjustable | Scirocco |
