mk1 golf gti front window black trims
(In Topic #211597)
front window gti trims and seat runner trims
hi all , was looking for some advice on how you put the black gti trims back onto the car , what type of glue or is it double sided tape also how do the trims that cover the seat runners fit on ? any advice will help cheers nigel
Depends on the trim installed.
On a "Cabriolet" black or black chrome waist trim they use a clip. (middle of the door)
The clips are white and go into pre-drilled holes in the wings and door panel.
Same with the lower rocker trim, they use a redish clip…little larger than the mid door.
I suppose it all depends on what type of trim. I had a Diesel Golf off the showroom that had stick on waist trim….
If you can show a picture of which trim you are talking about, and a pic of the rear of it, and then rocker (low beneath door edge), ( low waist ) above doors bottom edge or (Waist middle) of the door, we can better advise you.
the trim that i am looking to fit back on is on the front window outside the A pillars and the two seat runner trims cheers nigel
I thought that vw heritage still had the "A" pillar trim.
Can't assist you too much as I am across the pond.
171853293A
171853294A
These:
http://www.classic-vw.co.uk/mk1-golf-gti-a-post-spoiler-set-4505-p.asp
171853293A
171853294A
These:
