Lower part of the dash
(In Topic #210410)
Hi, i have a problem in my -91 mk1 cabriolet. Another ventilator inside is not blowing air, i can hear it blowing inside the dash but air is not coming from the ventile.
Is there any tutorials how to remove the lower part of the dash to get to see there whats going on ?
EDIT: Sorry for the english, i mean like taking the air vent off or somehow getting to see back to it is something wrong
Last edit: by Petrif91
Ok, there is some clarification needed?
The blower is working out the Defroster, even though you have it on full Front?
Here is a how do I safely remove my Vents with out breaking them all to pieces….
Cold Hands\ Whistleing Vents? | Volkswagen Owners Club Forum
Do you have air conditioning?
Yes, and you answered yes to above the issue is your
Defrost/full front servo.
You don't have to remove the lower dash, just the upper, and Fascia and controls, and radio so if you have a factory radio I hope you have the unlock code.
www.cabby-info.com has the how do you remove the Dash.
This is the a/c equipped defrost/full front servo.
It is the same as the one working the fresh air plenum under the hood. You can use the one under the hood to fix it…while you get a new one ordered.
The arm is Keyed, so don't get Jiggy with it.
Older non-a/c units. I think it still uses a cable….
I personally have only seen one no-air Vw cabby, and don't remember.
thank you ! I will check with your guide !
