is this repairable?
damage ive found on my shell
Okay so before someone says everythings repairable I no that its doable if I have time skills/money lol what im more interested in is has enyone done this repair and able to give me a better idear ofhow to go about it at or is the shell past it and sould I look for a new shell
So this is the damage  C:\fakepath\20140715_144228.jpg C:\fakepath\20140715_144153.jpg C:\fakepath\20140715_144212.jpg
The shell is all ready going to require a rear valence the inner wing on the pasinger side the supports on the front floor various other little bits and mabe rear beam mount repairs as I havent got under ther yet :/
anything is repairable, its just a case of do you love the car enough to go to the trouble!
High ther thanks for the reply my plan was to brace the car and cut out the section and replace it with a panle from a nother car is ther eny braceing behind the hinges that I have to watch out for?  Ive searched around the forum and other forums but cant find much info on repairs this section :/
brackign the car up will remove any risk of the chassis twisting, you wont find much to worry about behind there except what was left behind by whoever repaired it last!
Definitely repairable. If you remove the piece from another car, anything attached behind will be attached to the new panel. From memory the only thing behind there is the door check strap thingy and the back of the hinges.
Thanks for the info guys much appreciated shall crack on with it now an order some panles :)
