in need of seals bad...wet leg
(In Topic #96664)
does anyone know where i can get some seals from for my mk 1 golf cabby i need to replace all the door seals and especially the one where the windows meet the hood. by the way if anyone saw a goodlooking lad walking around elsecar meet with 1 right leg dripping that was me and it wasnt pee lol tnx alot
check out this post, same seal.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=38322
essentially before you replace seals check alignment, will find the vid useful for that, bits online cover a few things to check. see above post.
to get a new seal you are going to either check VW stock, CrazyQuiff, ebay or a scrapyard.
1988 1.8 carb Golf Clipper
also one other thought, are you sure your side tension cables are still good. Myn snapped either at the back where they go through the frame and right up front where they hook over the pin that holds them.
easy enough to replace, just a bit fiddly.
