Heater blower cover screws
(In Topic #215274)
Bought myself a cover for the blower fan on my 76' golf. The screws are also missing, so I wonder if anyone have a picture or know which screws are used for this cover? The threads in the chassis don't seem to accommodate regular machine screws.. Thanks
Early 77 year model Golf. 4-Door
http://www.realoem.me/Volkswagen/RDW/GO/1976/28/R/8/819/63000
I cant look up the part numbers right now as I dont have access to my PC which might show them in parts history. it gives you an idea at least. short term maybe a helper can hold some nuts inside the cabin for you to put a bolt into, or somethign along those lines
If you do go with screws and nuts I would suggest to use a rubber washer under a steel flat washer or screw head to seal the screw hole from water migration….
Last edit: by rubjonny
https://volkswagen.7zap.com/en/rdw/golf/go/1976-28/8/819-63000/
in comparison to the late setup, bolts with seal &, washer part 20:
https://volkswagen.7zap.com/en/rdw/golf/go/1983-7/8/819-147000/
