Drivers side window does not go all the way down
(In Topic #188415)
How to sort it?
I'll be taking the door apart 2moro and having a look
I had my door apart earlier to try and cure a rattle especially when closing the door. What I found was an old knife and the bottom of the winder track loose. There is a 10mm bolt that holds the winder track in place which you access via the bottom of the door. Whilst mine was slightly loose and contributing to the rattles it had allowed the track to twist slightly, the window like yours also would not fully go down. When I straightened the track and tightened it all worked fine. You might just want to check that when you are having a look.
Stephen
