Driver side heater pipe help!
(In Topic #219285)
hi guys, I have a hydraulic clutch conversion and as such a clutch cylinder /bracket on the steering column in place of where the drivers side heater pipe routing originally went. Anyone got some good ideas for re-routing the heater pipe to get around this issue?
thanks in advance
andrew
thanks in advance
andrew
Last edit: by andydlc
Use Copper pipe with a reverse flare bend on both ends bend adjust it where you need it to go and attach it with pipe clamps. I suppose you could solder on a compression coupler to keep the hose on as well.
