Clutch Bulkhead Repair Panel - Aluminium?
(In Topic #215880)
So i am currently pondering what to do with the clutch hole through the bulkhead. In the past someone has obviously 'had a go' and whacked a repair panel over the top of the split bulkhead. No prep behind it, so its rusty underneath, but the repair is solid.
One option would be to buy a repair panel, cut the old one out and replace with a nice clean panel, however everyone i find on the net appears to be aluminium? Is this right, or are they just galvanised? Does anyone know of where i could get this section in steel instead?
Thanks for any help you can give!
VW Golf Mk1 Cabriolet - Rivage In-Build. Again.
That way i can correct the POs work.
