Clipper correct interior? Gauges?
(In Topic #212378)
Looked on google and looks like there should be 3 gauges there.
My question is, was this for only gti models? If I put 3 gauges back in where is the hood switch meant to go?
Can't work out if this is a mod previous has done or is a mod for the clipper version.
One console fits all so to speak.
If you went down the road of 3 gauges which is not easy at all but possible and expensive.
Where would you relocate the electric roof switch?
Personally I think that's more time, money and effort for what it's worth and some.
Yeah they look cool but who looks at them when driving.
A set of working gauges, with all the necessary wiring if you can find them will set you back a packet!
Now you've confirmed one for all, just going to leave it - you're right it will no doubt cost a fortune.
What was a 'doesn't need much doing car' already has a shopping list of things that I'd like to do. Damn
NeilR said
I was thinking the same re switch location tbh as no real obvious place. I just didn't know what the standard was on the clipper, whether the previous owner had blanked it off or that's how it was meant to be.
Leave well alone is my advice and get on with the more important stuff!
I have seen on other euro cabbies the switch is located to the choke opening using a choke plate that takes the switch.
Got the round blanking plug from VW heritage so at least it'll look tidy now
The one to the left and low of the steering wheel, is 155957087
The cluster ones (under the Hazard) is:
321957087
