body parts removal
(In Topic #96177)
body parts removal
There is a plastic cover you can remove with a small driver then once removed you should see a X head screw, remove and your winder should come off, but I may be wrong on a cab.
www.cw-se.com
"Video et taceo"
"Video et taceo"
chriswizz said
Thank heavens for that, I thought you were going to cut a leg off
Depends if its a late cabb, mine you had to grab the black of the winder and prise it open, then pull off gently from the end thats attacthed to the car, which will expose a screw, make sure you've got right size screwdriver as they round quite easily….
Undo screw and pull off..
2 minute job when you know how
unsure if same as above as i am no good at 1. understanding insturctions without pictures and 2. writing instructions without a video of what i did
hello!
Grasp the plastic trim at the widest point and pull it away from the door card.
Once unclipped, move the trim to one side and you'll expose a X head screw.
Unscrew this then pull the handle off complete. Careful not to loose the screw down the side of the seat!
