Accelerator Pedel recon
(In Topic #215995)
Pedel has excessive play
I'm assuming it's just the bushing or some other sort of easily replaceable part. Also there's no rubber on it and hasn't been since I got it (which doesn't really bother me that much.
What parts do I need to completely overhaul it and make it like new?
I've seen both a cylindrical bush and a pedal rubber on VW heritage is there anything else I'd need?
Cars a Mk1 1.5GX
~Madferret
Mk1 1457cc 5door GX '83
as for the pedal pad it shouldnt have one, but you can get them from another model. original part number is 171721647, replaced with 7M3721647. can be bought from the dealer at 12.51+VAT
~Madferret
You need to press the pedal to the floor and make sure the throttle is fully open when the pedal is on the stop and not before.
But I tend to thing it is the bushing that the accell cable goes through at the top of the pedal. I had 2 of them turn to goo and fall out…. The last one that did it, I used a rubber bottle stopper whittled it down to size left a lip on one side drilled the center out. Fitted the lip side opposite to the cable and used the clip to hold all in place… it's been on about 5 years strong.
~Madferret
