Which mounts for O2A Gearbox?
(In Topic #183809)
Hi,
I'm changing my gearbox over from O20 to O2A and need a bit of help with which mounts to buy.
I'm using the Epytec mount here: with (edit) 64mm diameter. Does anyone have the rubber mount part number please? Is it available from VW?
Have they sent me too many rear mounts? I'm assuming there should only have been one in the box?
Also, do I need a new mount for the rear or will the existing O20 rear mount fit? (It is nearly new)
One final question does anyone have the part number for the bolts and nuts that attach the rear mount to the gearbox?
Thanks in advance,
Thanks in advance,
Last edit: by Mike 16vG60
yip only need one of them,o2o mount are no good
the rubber mount should be fine, for the round one the gearbox ones are NLA but if it takes engine mount ones you can buy those 171199214F. (engine ones are 74.4mm rather than 64.4mm)
Thanks - I already bought the 74mm from VW but it's OK as I want to change the polybush mount out from the cambelt side.
The ring in the gearbox mount calipers at exactly 64.00mm so I think I want part no 171199214H ?
£20 delivered for a febi one from vwspares, so not too bad
Febi 07578 Engine Mount | AVS Car Parts
yarp that be the very one
Do you want to sell the spare?
Might as well. PM'ed you
