1.8T 20V Conversion Wiring ECU, Ignition
wiring 1.8T conversion
I have started converting my 1.8T into the mk1 shell and now I have hit a wall at the wiring,
can anyone help me out,
do I keep the mk1 ECU and Ignition or do I use the mk4???
You need to use the mk4 engine loom and make it fit the mk1.  There are a few different ways to do this but the simplest is to just use the mk4 loom and rewire it to fit into the mk1 fuse box, easiest with an immo defeat on the ECU as you dont need the mk4 clocks and transponder then.  What year is the engine from?
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
the best way is as mentioned above, me and rubjonny  on here do wiring loom conversions if your stuck wioth wiring it up
Old dubs never die, they just get lower
The engine is out of a 1999.
would I have to get a professional to do the rewiring,
or could I do it my shelf??
The wiring loom conversions what way do they work is it just plug and play??
You can do it yourself if you have the ability to do it. Its not that tricky to do if you have a reasonable grasp of electrics and there's quite a lot of info out there on what you need to do.  Wiring diagrams are readily available for the 1.8T, if you're stuck with finding one PM me with the engine code and i'll more than likely have it.  If you want to run it minus the clocks you need an immo delete which I can do via post.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
rubjonny said
hi john how much of this info is usfull when putting a bora 2.0 8v into a mk1.
all mk4 wiring looms are basically the same for the fusebox connections so yeah it'll do you just fine :)
thanks for that, i aslo put a post about it in big block engins section , dont supose ou could answer them for me. ;)  prety please
