Speedo cable
(In Topic #206194)
Series 1 clocks to a mk2 box
Come across this issue today, I need to hook up my speedo but my mk1 has series 1 clocks but I've got a mk2 box on my G60 can anyone point me in the direction to sort this?
Threaded type on the left is what's on my clocks
The left below is what I need to fit the gearbox, other is just the original
The clocks end of the cable is my issue, other people must have got round this?? Thanks in advance for any help
you need an S1 1.0-1.3 speedo cable
RubJonny, the cable I had is a S1 1.0/1.3 but I want to run those clocks with a later box, all the small block cables seem to be threaded which is what I have but I need the unthreaded bolt in type on the box end. I can't seem to find anything that will work in the configuration without a custom cable? What was the connection like on the back of series 1 Gti clocks?push fit still? Sorry if I've not been very clear with this.
ah sorry for some reason I thought you wanted it for a 1.0-1.3 or 02a/j box! For the 020 box you need S1 1.5-1.6 speedo cable
Am I correct in saying it's the middle one I need? Are the clip and drive gear the same as later ones?
yes thats the one, the box end is the same for all 020. just make sure you get a new circlip as well otherwise the gear will fall off. if you have an old cable lying around then nick it off that.
part number is N 90015401, 22p+VAT from VW
Thanks a lot rubjonny as always, I've ordered one today, I've got the circlip and both colour drives as I'm not sure which one I'll need yet.
the gear colour depends on the differential inside your gearbox, so once you decide what code you are using you can use the ratio guide on brokes site to check the gear colour
020 GEAR RATIOS
020 GEAR RATIOS
Thanks rubjonny again, I used the ratio guide and sorted which one I needed, I have lost the new circlip I had though so ordered a new one.
