reverse phsycology - k-jet to carb question
(In Topic #191384)
super quick….8v engine 1990 - K-jet removed, carb in place, runs great apart from when left for any length of time the fuel appears to be draining back to the tank. The car will fire on the fuel in the float bowl run then stall, a few turns of the key and it runs again as normal. Fuel pump is mechanical, i'm appear to be missing something, any clues ?
I'll be out this stupid meeting in 4hrs or so starter for 10 please, or any related links please post up
should the in tank pick up pump be removed if there is a mechanical pump in place, wondering if hooking up the lift pump will keep fuel pressure in the lines but wont over feed the mechanical pump, is that even possible ? surely the swirl pot will shoot back any excess down the return line ?
The weber has an open vented bowl so that doesn't help.
I fitted a non return and that helped somewhat as it stops the fuel filter draining due to syphon so less cranking.
I have no swirlpot just tank, filter, pump, carb.
I did consider an electric pump so it fills the bowl without cranking. 5 secs of ignition should do it but decided it wasn't worth the hassle on a weekend play thing.
cheers.
all good now though
