mk4 1.8t clutch pedal
is it possible to use the full set up from donor car pedal and cylinders for hydraulic clutch
has it been done if so what is needed.(brake master cylinder and reservoir.holes in bulk head.extended pipe for pedal cylinder)
thinking i can go this way just wanted to know if possible.using 02j box and cable change.any advice welcome.
the mk4 clutch pedal is a separate assembly so as long as the height is ok it would be a case of drill a hole to suit and bolt it on. if the bulkhead is a bit weak then add some steel to reinforce
