Hydraulic brake bias and clutch pedal box
(In Topic #202485)
Make my own, crazy quiffs, pre made one?
I found crazy quiffs sell a modified standard pedal box, but it's £500?!?!?! And heard bad reviews of them about M/C leaking, for that money I don't want to hear that
There's a guy on eBay who makes modified original ones for £200 but I've sent him multiple messages with no reply
Also tired just caddys/retrofication with no luck, they just do clutch conversion, I emailed them about bias box with no reply
Though about fitting an overhung pedal box as you can pick them up for reasonable money with everything you need, but the steering column goes between the brake and clutch pedal which poses a problem
Floor mounted isn't really possible with the golf floor pan
Any other ideas? Links to people that have made theirs etc, any help would be much appreciated as this is the most expensive bit of my car! More so than the engine. And I need to get it all in first
I don't mind making my own, but seems a little daunting
Many thanks, Taylor
abfmk1 said
If I wanted to do this I would make (buy of ebay) a little metal bracket to weld to the steering column to take care of the clutch master cyl. I would then try putting the brake master cylinders/ balance bar on the end of the original linkage assy, just some fabrication/welding required. Not my idea, think I have seen a picture somewhere
Hmm, good shout! Those little weld on ends for the clutch are only £40 too
Once that's on it wouldn't take too much to make a housing on the existing box for the brake M/C. I had it in my head I'd need to completely make my own up from scratch and then weld my column to it. But this seems like a much better option. Thank you
If you manage to find it, mind linking me to the picture!
Taylor
The throttle pedal needed extended to make it inline with the other 2 pedals, steering columb fits with u-joint and all pedals work with no rubbing/hitting
I've currently dabbed my own hydro clutch which works perfect! And cut all the metal sides to make the pedal box out of. Just need to weld it all together
