G60 question
(In Topic #203991)
I have one question though that i can't seem to find the answer on Google. There is a little outlet on the throttle body, below the pipe that runs from the intercooler, you can see it in the below pictures:
My question is do I just plug this or is there meant to be a pipe on there to somewhere? When I block it with my finger the car runs fine but there is a high pitched noise,
Thanks in advance
ok cheers, do you know what the purpose of the pipe is?addicted said
Blank it off. The noise is probably air passing through the boost bypass valve, which is ok.
addicted said
It was connected to the carbon canister, along with the small pipe on the back of the throttle body..
