Ecu swap agu
(In Topic #215194)
Swap for newer ecu
if you mean you want a newer wideband ecu then you'll need to redo the wirign loom and change a few sensors on the engine, add a drive by wire pedal and throttle body etc
but if you're serious there are plenty codes to choose from, if the ecu is going to be remapped it doesnt really matter which one. you can even flash a lower spec ecu with bam firmware if you know what you are doing for example
They said I might need to go to the newer ecu set up.
Do you know of what the chips are I would need or were I could get them from or even a tuner with a good reputation for mapping these engine please.
see how you go, worst case main thign is having a new loom made. pedal isnt hard to mount its a flat plate with some bolts, plenty threads out there on it,. often people just bolt a bracket chopped out of a mk4 to the mk1 pedal box
