Coil overs running on tyre
Hi
I am fairly new to the mk1 scene and bought myself a mk1 cab 1993 about 6 weeks ago now.
My front suspension was shot so I bought myself some ta technics to run for about 6 months until I can afford a better set. I fitted new top mounts and coil overs yesterday. But now the front tyres at rubbing on the springs. I am running 14inch 6j p slots - so I wouldn't have thought this would have happened.
As anyone had the same issue?
Beans
Running the standsrd 185/65 tyres?
try lifting the suspension a bit, or spacers behind the wheels. The other thing to check is that the camber isn't too great.
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Yep had the same on almost all coilovers when you try to get low , major design flaw ! the adjusting platforms are to big , as borednow says put a spacer or adjust camber mate
Beans, exactly what borednow says…besides, the offset on the 6j wheels isn't the best, so space nd raise…
Ocean Blue '76 Golf LS - Sold
Black Campaign GTI
Silver Campaign GTI
Thanks guys. I have put 5mm spacers on the wheels and raised the suspension slightly and it has solved the issue. Thanks.
