cant get my engine level
(In Topic #186555)
aeb 1.8t into mk1
need some help here…i fitted the aeb 1.8t engine in my golf but now im having trouble getting the engine alligned
i bought these poly mounts
the way im holding it in the pic is apparently the wrong direction to fit them
when i put them in the correct way(thicker part of mount being up)
engine is higher up on driver side but the distance between cambelt tensioner and mount is ok
then i turn the poly mount around(the way im holding it in the pic) and engine is PERFECTLY level …but then
on the gearbox side im using brackets i bought from someone(the poly mounts are put in with thicker side up here)
anybody know whats wrong here?
Last edit: by shafiqnc
vw is the best
vw is the best
Old dubs never die, they just get lower
dik-van-dub said
you will find its not surpossed to sit level, most vag engines dont
maybe tilted to the back is nrmal?? but im sure nt suppsed to be higher up on driver side then it is on passenger?
vw is the best
abfmk1 said
Don't think it should tilt that much, think I would be looking at modifying the g/box mount.
yes im going with that aswell…also last night i figured that the tensioner was tensioned down instead of up so it clears pretty well now.,.just need to get engine level
does the intake usually hit up against the bonnet on these conversions?im using agu intake
vw is the best
shafiqnc said
that tensionor is way to close some thing not right there
peterg60 said
so ive figured that the tensioner was tensioned downwards instead of up(bought the engine as is)
definitely moved it a bit further away now…still need to sort the mounts out tho..
vw is the best
Member 125 - 2005
