Brake Force Regulator
(In Topic #201233)
Needed ?
Hello All,
As above, Brake Force Regulators; Are they needed when going to a Disk Brake'd rear setup ?
I was leisurely flicking through the VW Heritage braking section and came a cross these - https://www.vwheritage.com/shop/golf-mk1/WC698396/brake-force-regulator-3-15-for-mk1-golf-rear-disc-conversion/?crumbStartPage=2&crumbStartRow=49
Not sure I've ever come across them in any build threads etc… just after opinions on a £150+ outlay …
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
yes they are, you either need the mk1 tintop lever operated type which is mounted under the car near the rear beam, or the later cab/rocco type which is mounted to the master cylinder as per the link above
Ah ok, makes sense now.
Mines a GTI so has the lever type next to the beam.
CHeers,
CHeers,
'83 MK1 Golf GTI
alrighty all sorted then
