APX ecu into a MK1 with cable throttle .
(In Topic #208646)
You'd have to source an AGU ecu/loom/sensors and use them on your APX engine. Injectors are a different size too..
the tt looms are basically the same as MK4 so this will cover you:
http://www.clubgti.com/showthread.php?267196
its a narrow band pre-cat lambda as well, i.e. 4 pins. if you have 2x lambda plugs 6 pin and 4 then you have the wrong loom for an APX ecu
the front lambda is wired like so:
1 - blue/yellow - fuel pump power (lambda heater power)
2 - brown/green - ecu pin 5
3 - green - ecu pin 51
4 - black - ecu pin 70
If you like you could let me know where the other plug wires go, just to confirm 100% its a post cat lambda and not something else random
the fact yours is at least narrowband helps as that side should all be good, just double check the wiring to the pre-cat as above
