1.8t with solid flywheel
(In Topic #207982)
Knocking noise
I have a agu 1.8t in my mk1 running a 5 speed o2j gearbox and a lighted & balance solid flywheel.
I'm just wondering if they are normally noisy. Knocking sound and if I blip the throttle it knocks. I have just replaced it because I had one fail so I want to make sure it's normal for them to be noisy or if not then I need to get the box of before any damage is done.
Any help or advice would be great 👍.
Kind regards
I just sold my mk2 with agu/02j which wasn't noisy & it was stripped out so would have noticed
Last edit: by Cushti
Mine might have been fine as it was just a normal G60 smf
I made mistake 6 yr ago with t5 transporter wrecked recon gearbox in 5k miles as the gearbox needs the damper from dual mass cost me £750 for gearbox case it smashed the bearing damaged case
My crafter just being done I put dual back in never again put solid in
I thought was going be Better with solid but I was so wrong
Was advised after it broke gearbox that they need dual mass to cushion gearbox
Sent from my KYOCERA-C6745 using Tapatalk
