1.8T Rebuild Help Needed
Hi Guys,
When Rebuilding a 1.8T what do I do when Ive no heater in the car (Im doing away with it for a cleaner look in the bay) do I just bung the pipes or do i make my own to keep it cleaner?
Also when rebuilding it, I am replacing big end bearing, all gaskets, water pump & timing belt anything else use guys would recommend to replace while im doing this?
Thanks in advance :)
Aaron
i run no heaters and just left the the 2 pipes hanging in bay. if u want smooth look just pull them and weld and smooth the to holes. as for engine. oil pump and pick up pipe i would replace if u rebuilding what i did was have new stems in valves and new  cam chain tensioner, head skimmed.
Yeah Peter that's what ive done, but just wondering what I do on the engine side regarding pipes if I was to bung any up that my have ran to the too the ones which come out of the heater? If that makes sense?
Oh sorry. U just use a t piece to join the 2 pipes on engine making it a loop. One is a metal pipe other is a plastic . I put some pic of my 1 so U get a better idea soon
Aww right im with you, I suppose I never thought of making a loop in it, basic plumbing really then lol Yeah pop a wee picture up just for reference if you can anyway be appreciated  :)
im working on car trm so will get u some pics : )
Super buddy thanks :)
sorry i ant got no pic ant had time to get to car  but im on the car all weekend so will defo post weekend
here you go m8 as you can see ive bypass the heaters. simple t pieces with some silicon tubing. not had no leaks
Thanks pal!!  :thumbs:  :thumbs:
