1.8T AUM - drive by throttle replaced by cable - Which OEM ECU and loom to run?
(In Topic #213114)
I was wondering if its possible to run an 1.8T AUM running a drive by cable setup (dBW removed) on the standard ECU and loom?…. or would a loom/ECU be required from another engine code?
I brought my mk1 with a AUM running an Emerald ECU which needs mapping but after digging around the wiring loom it looks like the previous owner didn't wire in the N75 or Lambda and god knows what else…. so i'm just weighing up my options to ditch and sell the Emerald and go back to OEM management and keep nice features like OBD for diagnostics and general reliability….only issue I can see is the AUM was converted to drive by cable.
Any help would be greatly appreciated…thanks in advance!
if you want DBC then it'll be fine to convert but you need all the dbc sensors that differ plus the ecu and loom to match it.
dbw isnt hard to sort though the pedal is flat mounted to bulkhead with 4 bolts
