1.6d two abf
(In Topic #200895)
http://www.clubgti.com/showthread.php?249714
only real difference engine loom side for splicing is the rev counter wire on a diesel is in the lighting loom, look at the 2 pin plug near the battery where the alternator loom plugs in. run that to the coil -ve and you're sorted, leave the blue as it is and hook up to the abf alt blue wire
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
get the diagnostics jumper and port too with the grey/white and yellow wiring uncut, the red/white and brown tap into the main dash harness near the middle so chase those back and snip off.
