1.1--16v conv.help needed please!
Anybody local to me that can help me out (Blackpool) for wages
My 1.1 now has a 1.8kr 16v engine now mounted with Bogg bro carb set up
I looking for someone that can do the electric and fuel pluming for me
Been to 2 local vw specialist garages but not interested in convention work
Please Help
I have just used Mr Jvw in leigh to do my wiring he did a really neat job of it mine was a 1.1
is it the later style blade fusebox? all you need to do is fit a kjet fuel relay to fusebox and add a pin to e/14, or use the larger spade N with an inline fuse. GSF sell them part number 935VG0090
if its the early fusebox you'll have to add your above relay above the fusebox, tap into the red/black wire on engine loom for rev signal, then use spades on fusebox for ignition and live feeds and earth to claw above fusebox:
30 - live - spade H on fusebox
15 - ignition live - spade G/3 on fusebox
31 - earth to claw above fusebox
31b - rev counter - to thin red/black wire on engien loom to coil -ve
87 - to fuel pump
if possible try to get a VW relay holder as it will clip above the fusebox, you'll need latched spades to pop into the sockets or just chop a load off the donor car. plenty vws come with the relay holders, mk1/2/3 etc
edit: just make sure the relay holder is the right one for your pump relay, ideally take the relay into the scrappy with you top check. mk3 golf with abs will tend to have the sockets you need.  you could use pre-insulated terminals without a relay holder too you would just have to take care how you mount it to the car to avoid any possibility of shorts
