02J shifter help
(In Topic #200707)
I am in the middle of a g60 conversion, I am using the g60 02A gearbox but have swapped the shifter tower out for an 02J one
I picked up the shifter and cables from a polo but the cables don't seem to fit on to the tower
This is one of the pegs on the shifter tower:
And this is the end of the cables:
It looks like the peg on the shifter tower should go all the way through the end of the cable with a clip on the other side but this isn't possible with these cables!?
Can I just change the end of these cables or do I need to get a different shifter and cables, if so what are the best ones to get?
Old dubs never die, they just get lower
dik-van-dub said
you have the wrong polo shifter, you need a 9n shifter from a bigblock engine car
Thanks, will I be able to swap the ends or is it a case of a new shifter?
you have 2 different 'late' mk4 shifters you have a missmatch with the cable ends and the tower, they're still both late
rubjonny said
you just need to either change the cable ends for the pin style, or change the parts on the tower to the ball style.
Thanks! I'll change the cable ends over, I have a shifter from a golf with right ends but looks like it'll be a bit long
