Wont tick over
(In Topic #129000)
Wont tick over
It will start but wont tick over with out the chaoke part out or constant reving on throttle.
Any help or suggestions welcome based in Northampton
Paul
What did you set your points at? (it should be 0.4mm)
Is your timing set up correctly
Bobby
Bobby
Wont tick over
Will be trying to run from gallon can beside car at the week end to isolate the tank and fuel pipes if not that will try service kit for the carb.
Any other ideas welcome
Paul
Real golfers don't play with clubs
Bobby
Bobby
Wont tick over
The fuel cut of solenoid is making clicking noise and moving when ignition turned on and off so I think that's ok carb mounting gasket looks fine, have got carb in bits found some very small debris in the two jets on the left side of carb when looking from the top.
There are two adjustment screws on the right hand side one large this one will come out and is clean the smaller one will turn ok and go in so it stops but when it's undone I can't remove it from the carb body will give the carb a good clean and try again in the morning.
Now its ticking over
thanks for all the help no doubt will be back again
Paul
Bobby
Bobby
