will this fit help please
(In Topic #119548)
Regards Volkswarren
Regards Volkswarren
Regards Volkswarren
sure the exhaust ports line up.
Jon.
the reason tha manifold doesn't fit is because the 1.3 is a small block, and the 1.8 is a big block.
if you look between the 2 sections on here you'll see the differences. Mainly that the small block has the inlet and exhaust manifolds on opposite sides of the engine, the big block has them on the same side (the back) one above the other.
supersprint do do a manifold for the small block engines,
http://motorsportworld…=/supersprint-exhaust.htm
Jon.
What doesn't kill me can only make me stronger.
Mk1 will be back.
Mk1 will be back.
think it was posted above but you'll need to move the o/s engine mount back into the big block position. there are loads of pics about it on here if you search!
Jon.
