what engine options straight swap
(In Topic #128772)
i took it off the road about 2yrs ago when the engine fell out (stupid low gearbox mount lol)
anyway, i no longer have the engine or gearbox or driveshafts.
what options have i got that will go straight in, dont wana mess around with the loom or mounts unless its an easy loom modification. its not that i cant, its just i would rather chuck an engine in and drive it!
ive heard people say mk3polo engines or mk2 golf engines but which ones drop straight in?
it was originally a 1.3 4speed
cheers for your help
owns:
mk1 jetta 1983 blue
1966 beetle on hydros
1959 lowlight karmann ghia
mk1 jetta 1983 blue
Right, bolt in swaps.
1.1, 1.3 solid lifter engine from an early mk1, mk2 golf or mk1 or mk2 polo
1.1, 1.3 hydraulic lifter engine from a later mk2 polo or mk2 golf
1.1, 1.3 hydraulic lifter engine from a later mk3 polo with fuel injection.
1.3 hydraulic lifter engine from a mk3 polo gt
1.3 hydraulic lifet engine from a polo G40
You can also use the later mk4 polo engines, the 1.3, the 1.4 and the 1.6. ( with the added complication of electronic fuel injection/etc - you can always use a carb and dizzy off an earlier polo to get you running.
With the exception of the very early solid lifter stuff, you WILL have to do some wiring , as the hydraulic lifter lumps have electronic ignition.
Also with the fuel injection lumps you'll have to sort out the fuel lines and pump for the injection system.
Gearbox's - any four speed cable clutch rod change box from any of the above vehicles will fit, for the 5 speed you'll need to make/bodge up a mount for the right hand side of the box as they are different.
So, get down the breakers yard - find a mk1 golf ( haha ) mk2 polo, or mk2 golf…..if you want the easiest option.
I'm personally building a hydraulic lifter 1.3 with bike carbs, GT cam, ashley exhaust and megajolt mappable ignition, with a mk2 polo 5 speed box - lovely.
Real golfers don't play with clubs
ur project sounds awesome, if i didnt want the car straight on the road id whack a AAZ in it, but i need a winter car haha.
got a couple of spare golfs but theyre all big block and i need those bits for my caddy!
il have a mooch about for some of the above mentioned cars/engines and see where i get!
cheeeers!
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
If you DO find some polo 5 speed boxes, I need another one ( two small block golfs ! )
change dizzy for a vac advance one from mk2 golf/polo carby and fit all mk2 golf/polo carby setup and no real wiring of any decription is required.
5 speed swap isnt bolt in tho im afraid, need to weld haf polo 5 speed box mount to half mk1 golfy one
