weber on a 1.1
(In Topic #80457)
just have a mess, oh and use the factory settings as ur starting point, should run on this, then fine tune from there :wink:
theyre great when their going :mrgreen: got one on mine, i didnt originaly fit it but i did remove, strip and clean it and it went back on sweet as a nut is it new??? :? if not it may need a clean, do the needles/jets.
spot on with a k&n too :wink: :mrgreen:
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
i live to dub....
the car runs fine, but has to run with the choke, also, after the idle just goes all the way down and dies, if you press the accelerator too quick it hesitates then starts, it dies when you drive in second sometimes, and when you break hard (Take your foot off the accelorater) it dies….its obviously a carb tuning problem i tried to fix it but no avail…the carb has been cleaned recently and ground is in place everything is fine just the tuneing…. help PLEASE
i live to dub....
rotor arm
ignition leads
plugs
and a bottle of redx
check the dizzy too :wink:
just the normal culprets for makin the car run crap, apart from carboration, or a tired out engine :?
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
