vw 1.3 oil coming up from the breather????
(In Topic #145866)
I have a golf 1.3 carb and the other day I was changing the plugs and noticed oil from the intake and when I opened it oil can pouring out and the air filter was socked in oil.When the car is idling there is no oil coming out of the breather but after I have driven the car oil starts dripping from the intake onto the exhaust manifold and starts to smoke.The oil level is fine,water level is fine no oil in the water,starts easy.I have a suspicion it might be the PCV valve and I am no expert but I can't seem to find it,any help will be appreciated.
Best regards L_O_O_M
Thank for the reply.I let the car idle for awhile an what I noticed is when it idles nothing happens but when I let the engine idle on higher rpm's then after awhile oil starts spitting out the breather.Thanks for your opinion.
I was looking at the breather hole and it looked dirty is there anything I can use to clean the oil return hole with the welding rod,I will look for a the same breather at a parts shop.(I live in south Africa)
Regards
www.survivingsouthafrica.org
