Very bad economy
(In Topic #88544)
Very bad economy
Is there anything I can do to make it any more economical as its crippling me at the mo
mk1 1.1 C
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
mk1 1.1 C
If by "all the way out" you mean unscrewed (anti-clockwise) then this will make the mixture at idle richer.
You are correct there is no mixture screw for normal running on a Weber - that is why it's so important that the Jet sizes are correct (especially the Mains and Air Corrector/Emulsion Tubes).
Have you checked yours against the 1.1 Spec in the Weber Guide I sent you ?
If after a good run they are black and sooty - it's too rich.
Does it run OK ?
I have checked it against the guide you sent and its the same so I dont think that is the problem. It does run well in my oppinion, it has never stuttered or stalled on me and it pulls well.
Economy has actually been better over the last few days. Im thinking it might have been down to the fact the car had sat around for 6 months prior to me passing my test and it just needed a good run.
If you have any other suggestions they are more than welcome.
Thanks.
mk1 1.1 C
overmind said
I was under the impression that the further out the screw was the leaner the mixture would be. I'll adjust this asap then.
If you think about it, it's a pointed screw in a hole (through which the fuel flows) if you screw it up (clockwise) it closes the hole and reduces the fuel flow at idle - leaner.
If you unscrew it (anti-clockwise) it opens the hole and allows more fuel flow at idle - richer.
Screw it in until it starts to run rough - then slowly out until it 'hunts' (is a bit more eager) and then set it between the two positions, slightly closer to rough.
By the way how are you determining that the economy is 'bad' ?
…and what do the plugs look like ?…
I thought with a smaller engine such as the 1.1 fuel economy would be around 35mpg, then again the 4 speed box doesnt do it any favours. The car smells rich on idle (excess fuel vapours in the exhaust.) However it doesnt appear to be running rich (spark plugs wernt too bad) so maybe its just something im going to have to get used to. :dontknow:
Cheers.
mk1 1.1 C
tenner does me about 30miles id say, total estimation havent really been checking the milage but I only get about 3 days out of it.
'83 1.5 Gx (picture coming soon)
Mint MK1 Wanted PM me
MK1_Arron said
Economy is bad on mine WITHOUT the weber on!
thats awful! thats like 15mpg! my scirocco 1.8 with a webber gets 70miles to a tenner round town 8O and i thought that was bad!
Bog standard 1300 Driver!
