Two coils in three days!
(In Topic #150477)
Yesterday morning the car started and drove like a champ; got me to work and back fine.
This morning the car did exactly the same as before; started then died. No spark again.
The coil is dead but I'm not putting another one on until I've worked out why the car has developed a taste for them. Never had a problem with this before and the whole ignition system was replaced around september time.
Any ideas would be very welcome!
Cheers.
Im not sure if the Mk1 had a ballast wire, and if so was it to the fuse box or straight to the starter?
Sorry if any confusion the car is a 1983 Mk1 Jetta 1.3
Basically I am not sure if I need a 12V coil or the same again and sort out ballast issue.
Cheers.
Put a new coil on after checking all was ok and now no spark at all again. Very strange, as although the coil was getting fried by a constant 12V it did work before.
Anyway, any ideas would be cracking as usual.
Cheers.
Anyway….problem mostly solved. I rewired the ballast wire to the fusebox and now have a solid spark with 12V on cranking and 9V when running.
Also the pigtail on the points was a little bent and kept shorting out on the inside of the distributor.
Adding to the issues the idle cut off valve was not getting 12V, another wiring fault in the fusebox!
With the above sorted I drove a 2 hour trip to pick up some new wheels yesterday. Drove like a champ there but the same cannot be said for the way back!
Was dying a bit on full throttle but if eased on it got better and would be fine.
Makes me want to look at the carb but as its a new weber Im erring towards ignition.
Took it for a drive today and the same again. Fine in first and second but if ragged in third and fourth it will bog and backfire from the carb.
Any help on this new issue would be amazing as I have an interview at Red Bull tomorrow and would ideally like to get there!!
Cheers.
That's all I got I;m afraid, my knowledge is basically 'test everything until the bloody thing works'…. good luck!
Found numerous faults in the ingnition set up even after the ballast was sorted. Vac advance wasnt brilliant, oil was leaking into the dizzy and there seemed to be issues in the dizzy itself as new points weren't helping.
Found a bosch dizzy on ebay for a couple of squid. Whacked it on and she went like she had never gone before! Bearing in mind the dizzy seemed to have knackered points and had been sat in a garage for a long time.
I then got a accuspark kit, put a new coil and leads on ans she has been perfect ever since.
Have to reccomend the accuspark kit to anyone with a carb model with the traditional points. Made a world of difference and nice to know I never have to look at the points again. (I do keep points in the glovebox just in case mind!)
Cheers for the help.
http://www.accuspark.co.uk/car_search.html
Not bad considering the price of other units, they are meant to be pretty good too.
Pretty sure they have an ebay store too.
Anyway….accuspark!
Nice one You wont regret it! Makes a world of difference. Got mine off there eBay store. Only issue is needing a bosch dizzy which can be a pain to find.
Good luck with sorting the rad issues!
Cheers.
I think they use the Bosch dizzy on polos and other engines so you might be lucky and find one if you have a decullier one.
Hope you don't have too much of a faff to fit it as its such a good and easy mod.
Cheers.
