tappets
(In Topic #77068)
tappets
i think i need to replace my tappets ive got a rattling from the top of my engine. it gets worse as the revs get higher. engine code is py, they are hydraulic and should self adjust. before i fork out on a new set is there a way of testing the old ones?
should i replace the whole lot or find which ones have gone? it seems to be worse at the timing case end of the engine.
simon
simon
Could it be the same problem i have with the cam being worn out?
If its possible pop your rocker cover off and have a look at the condition of the camshaft. If theres a flat spot on the end of the lobe or a 'divot' then the ratlling noise could be the cam.
Also check your timing belt tensioner.
J.
J.
been speaking to the technicians at work going to replace the tappets weekend. cam is fine
simon
simon
cool.
swapped the tappets the weekend, glad to say it was them and wasnt to hard to do! engine is loads quieter and im happy again.
simon
simon
