small block 1272 GF and VDO gauges
(In Topic #144358)
I have a 0-5 bar oil pressure and oil temp gauge up to 170 deg celcius
I would like to preserve the oil light on dash so i presume am looking for dual pole oil pressure sender (not sure which one - diff pressure ratings dep on location?)
Would really appreciate part no.s of appropriate sender/sensors and their locations
PS whats a good gauge oil pressure and temp for a GF?
Many thanks
Nik
other thing to check if its just the 1 switch is what rating it is, this will determine which oil pressure sender you use as there are 2 types, one for the high pressure 1.8bar switch and one for the low pressure 0.25/0.3bar switch.
if you dont have a 1.8 or 0.3 bar sender then you'll have to use a T piece or maybe even 2 and keep the original sender(s)
I didn't realise there was such a variability in what swtiches a GF would have. Would it be a safe bet to get a dual pole sensor 0.3 bar and an M10 T piece?
If there are 2 switches on the GF head, it it better to go for one rather than the other with a sender?
i know that big blocks use 0.3 and 1.8bar senders but I'm not so sure what the small block uses. also early mk1s only use 1 pressure switch for the dash so that leaves a spare oil tapping.
once you find out what your sensor(s) are then you can decide the options for your vdo pressure sender, the most common is 0.3 bar warning, 0-5bar gauge. you can get 1.8bar warning ones, plus some are for 1-10bar gauge too.
it doesnt really matter what you get and where you put it, just that the pressure sensor is the right spec for the gauge and dash buzzer circuit, and ou replace the right pressure warning switch
Is it better to get a single pole sender and use a T piece for the sake of the original oil light switch?
PS. Which /Where's the best place for an oil temp sensor/switch for the oil temp switch?
the oil sender will need to go into the other hole along with the 2nd pressure switch using a T piece, failing that you can get sump plug adaptors and dipstick sensors
Nik
