Service on a 1.3
(In Topic #75708)
Service on a 1.3
I have not got the haynes yet so i was wondering what and where i can get the bits:
Oil, synta silver? oil filter, plugs (bosch) and air filter
All those things u listed, and also a fuel filter which is under ?1.00.
'83 Golf GTI Lhasa Green
'82 Golf GTI Mars Red
'89 Corrado 16v Tornado Red
'95 Golf CL Dragon Green
1983 1100 C
1983 1100 C
when you mention the points and condensor, what are these?
I'll have to get a themostat as it's a SA import so it could still have the SA thermostat!
Also as it's a 1996 SA import, shall i take it i can say it's a 1984 model, to save confusion at GSF?
o
I have practically renewed my KR engine on my MK2, but have never dabbled with a carb, backwards i know!
Care to tell me what they are, so i can learn before i get the manual please?
I assumed you had an early 80's 1.3 mk1. Unlikey your car will have them as points and condensors were phased out in the early/mid eighties in favour of more reliable electronic ignition.
1983 1100 C
1983 1100 C
**images don't seem to be showing - you can copy and paste into a new window to view**
Does it look like the later type?
Thanks again
1983 1100 C
1983 1100 C
dcuk - it's on the log book as a 1.3, what can i check to double make sure, any codes or anything that will tell?
You sure thats a 1.3 engine? looks like a 1.5/1.6?
Yes good point - I missed that ops: . Look like a big block engine (engine is canted back). Traditionally 1.1/1.3 VW engines are canted forward. What is the full cc rating?
1983 1100 C
1983 1100 C
The engine number is normally found at the top of the engine block - below the 3rd spark plug from memory.
Its probably covered in oil and dirt so you'l have to clean that area to find it.
The engine code will the first two letters of that number.
Although just remembered that fellow member Bert told me it was a - big block 1.3,engine code GY!
