Seized 1,3 engine
(In Topic #145837)
Seized 1,3 engine
Drop the block out then took the sump off it looks like
Its the piston that are stuck so put loads of wd40 in the bores is there
Anything better thx billy
Good luck with that :cry:
WD40 is as good as it gets for penatrating only other thing I would try is a blow torch to heat up the liners a bit then get a short peice of scaffold pole or 2 inch pipe on top of the piston and belt it with a hammer.
Good luck :wink:
Chances are you will need a re-bore and a new set of pistons and oversize rings, not a massive job but worth having done by a reputable engineering company, good news is when its done you know it will be a grand engine providing you have all the bearings and seals replaced..
