radiator upgrade
(In Topic #75498)
radiator upgrade
However, as mentioned above, why do you need to change the radiator? - my '82 1.3 ("C" chassis) was perfect at all temperatures and engine speeds with the expansion tank in the rad. If you are getting overheating, it's not a design issue - let us know, and we'll tell you what's knackered…
matt-mk1 said
i wanted to upgrade because iv got bike carbs on my 1.3gt engine and i usually drive it pretty hard. im just a bit worried about it overheating because i havnt figured out how to match the gt's temp sensor to my 1.1 dash…plus it can only be a good thing that its got a bigger radiator cant it?? :dontknow:
The temp sensor from the 1.3GT should match the 1.1 gauge in the dash anyway, but if it doesn't, you can use a 1.1 temp sender on the 1.3GT engine - the scale of temp's that they both need to read are very similar, if not identical. The only differences that you might note is that the thermostat rating (the temp at which it opens) might be different.
Having a too-big radiator is probably not as bad as having a too-small one, but it can make your engine run a bit cool, which is a bad thing (tolerances are designed for when the engine is at the correct temp, and all the various parts have expanded by the expected amount). Also your fuel consumption will be poorer when the engine is a bit cold.
Even with bike carbs, a well maintained* engine shouldn't overheat, and these small-block VW ones don't have any particular weak spots.
I'd get the gauge working first, and then see how it goes…
*well-maintained means, in this case, a good coolant pump, correct ratios of VAG coolant to (soft) water, and all hoses and waterways in the head and block being in good condition, not silted up or rusty
thanks again.
