Radiator fan switch change
(In Topic #144169)
Do I simply drain some coolant out the system so it doesn't flown out when I unscrew the switch? Then simply rescrew the new one and top up coolant?
Seems daft I give a garage £50 for a £10 part and half hour work
Ta
Neil
i appear to know what i'm doing…..so i must know what i'm doing
Don't donut when waters hot though it burns a bit
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Cheers for quick reply chief, appreciate it
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
the first step in checking the operation of your fan is NOT to start changing components and a decent garage wouldnt do it just for the fun of it.
Im not saying its not at fault but if you dont carry out the diagnosis first your just running about in the dark!
At least check to make sure you have power at the switch and then bridge the terminals to make sure the fan starts up.
MIND YOUR FINGERS THOUGH
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
nice one
I like it when things work first time . Phew.
Thanks all for input. Decided against coolant change as may well need new rad in coming months as mine looks lil worse fr wear so will do all then.
Cheers guys
1983 Golf 1.3 Driver:
