polo engine (facelift model)
(In Topic #74735)
cheers,
paul
the wiring of your old engine can be used as you wont be running mpi with an ecu
Chris
the engine mounts on the car do not need changing if you use a 4speed box, im not sure what needs changing if you use a 5speed box…all that i changed is the mount that is attached to the engine, this needs changing for the one off the 1.1 or older 1.3
ignition wise, i used the hall sender and coil etc from a late carbed model polo or golf…this was easy too, literally 3 or 4 wires to connect.
you also need an electronic fuel pump if you go for a newer engine.
hope some of that is usefull.
Chris
which engine are you using the 1 litre or 1.3 as i may have a chipped ecu and induction kit forsale soon if your interested
I've got the 1.3 engine. I'd already talked to Poloace on the Porka forums, but I'm having running problems so was holding off until I'd sorted them. Tell me what you've got.
