One of my Ho's aint doing what she should be. Sham-one!
(In Topic #74411)
Well, to be more specific - Vacuum ho's - anyone know where this one is sposed to goto? its always been disconnected on my car - i guess i don't need it so whats it for ? [aftermarket weber carb for 1.1 btw]
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Does another vacuum ho - I mean hose, go to the vacuum capsule on the side of the distributor? If not, this might be the one.
i'm pretty sure this one wouldn't reach, but i'll check it out later, cheers for the tip
'83 Mars Red 1.1 C
mine used to go to the round block thing on the top of the air intake tube...it kept comin off so i blocked it with a screw and some seleant 8)
1272 driver with a magic tree!!
if its same as other webers may be the air housing for cold start up etc, block it then unblock it see if theres a difference on cold start up
It may be for the flap inside the air box, where when it's closed it will only take in air from the lower intake which should be connected to the warm air intake on the exhaust manifold. I think thats where it goes, correct me if im wrong
