new warm air deflector plate needed
(In Topic #109156)
im trying to restore a 1983 1300 driver , does anyone know if and where you can get a new warm air deflector plate from?
many thanks
i got one from a polo at a breakers, was the same. I think its was an M or L reg one -not sure if thats a mk2 or 3 polo. Exact fit but the 90 degree pipe from it is a slightly larger bore one so has now has a larger bore warm air hose from original - i crimped the foil based hose that i used with a jublilee clip at the air filter housing end
Warm air deflector otherwise seems the same and fine.
The fact it was from a newer polo meant that it had no corosion and i painted it with VHT paint before using anyway
Searched for ages before for an otherwise obsolete part
Re: new warm air deflector plate needed
baldy412 said
hello,
many thanks
nice one ill look into that, thanks for your help
